The tablet display is divided to two parts (halves) so that the right part shows much lighter than the left part all the time. How to correct it or is that a malware that come with APUS that installed there automatically with some update?
Printable View
Welcome to Android Central.
You could try a Cache Partition wipe, also Safe Mode, but the fault sounds bad to me, whether software or hardware.
Try changing the brightness settings. There could be an option for some features that's related to your device.
