1. Gracemind's Avatar
    I liked the details weather on the S5 and wanted on the S6. I tried using the Xwidget app, but the weather widget doesn't show the right location and it don't update itself.
    04-27-2015 08:45 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. You can try to pull the .apk file for the app from the S5 and installing it on the S6. However, I am not totally sure this will work. If the weather widget is not configured for the S6 the install will fail (If I had to guess, I think this will wind up happening).
    04-27-2015 09:03 AM
  1. Replies: 83
    Last Post: 05-24-2015, 01:16 PM
  2. Replies: 2
    Last Post: 05-20-2015, 10:44 AM
  3. How can I stream YouTube to my Vizio tv?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-28-2015, 01:28 AM
  4. Replies: 1
    Last Post: 04-28-2015, 01:27 AM
  5. Why is my music player automatically pausing after 15/20 mins?
    By sbajewicz in forum Legacy Android & Other OS's
    Last Post: 04-27-2015, 12:40 PM
