1. AC Question's Avatar
    I use Android 4.2.2. I have three apps that are supposed to let me know me know when I receive a new message - Facebook messenger, Gmail and Skype. Over WLAN I get notifications for all of them instantly.
    Notification for Facebook messenger also works fine over 3G.
    I don't receive notification from Gmail and Skype over 3G. But if I run them and exit them, I get notifications normally afterwards.
    Any idea how to fix it?
    04-30-2015 06:52 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Does this persist after a reboot?
    04-30-2015 07:57 PM
  3. alenmilky's Avatar
    Thx! Phone is Galaxy S3. I tried to reboot phone, reboot apps, clear app data & reinstall app so far.
    05-01-2015 07:41 AM
  4. B. Diddy's Avatar
    Try wiping the cache partition: http://forums.androidcentral.com/sam...2-s3-tab2.html
    05-01-2015 11:37 AM
  5. alenmilky's Avatar
    Will this leave SMSes, address book and accounts intact?
    05-01-2015 04:01 PM
  6. B. Diddy's Avatar
    Yes. The cache partition only holds temporary data.
    05-01-2015 04:49 PM
  7. alenmilky's Avatar
    Did it, no change, hm...
    05-02-2015 04:24 PM
  8. B. Diddy's Avatar
    Not sure what the next step should be, besides backing up your data and trying a factory reset.
    05-03-2015 12:57 AM
  9. alenmilky's Avatar
    I was checking up apps that were loaded and I discovered that Facebook messenger is started in the background when phone is booting. That's why I receive notification from it. Skype and Gmail are not started in the background by Android. Any way for them to be started in the background while phone is booting?
    05-03-2015 11:49 AM
  10. B. Diddy's Avatar
    That's strange--it shouldn't matter. Gmail should still be able to notify you of new mail, even if it doesn't open automatically upon startup.
    05-03-2015 07:11 PM
  1. Lockscreen won't allow no security or swipe
    By ejcrossl in forum Samsung Galaxy Note 4
    Last Post: 10-26-2016, 01:35 AM
  2. Why have my pop up contacts stop working?
    Last Post: 04-30-2015, 08:09 PM
  3. Replies: 1
    Last Post: 04-30-2015, 08:00 PM
  4. Replies: 1
    Last Post: 04-30-2015, 06:21 PM
