I suppose you mean it's saying that you are out of space to install apps on your device.
Install this simple little app. It's very small and will install in very limited space. It will tell you how much space you actually have left for installing apps:
https://forums.androidcentral.com/e?...token=feNqbRIl
To make space you can:
Delete some texts or emails. If you really have lots, this can help.
Uninstall app updates.
Uninstall apps.
Clear cache files. However, that will only make space temporarily as cache files will rebuild over time. Also, while clearing cache files won't hurt anything, they're there to speed up operation and should be left alone.
Android since v1.0. Linux user since 2001.
