1. AC Question's Avatar
    My phone suddenly won't recognize charger or charge when plugged into wall outlet. When I plug it into my laptop, it both recognizes & charges via usb. What gives & how can I fix it, short of replacing the phone or charging port?
    05-02-2015 12:33 PM
  2. Kerias's Avatar
    Sometimes that happens with old chargers or cables. I think your best option is to get another, because I think the charger isn't quite compatible with the phone you're using. If it's a new charger, I'd check the cable, but it seems like the cable is working fine. Hope that helps at least a little
    05-02-2015 01:47 PM
  3. Matt247's Avatar
    Is it original charger?
    05-02-2015 09:21 PM
  1. Fast charge spoils me
    By grimister in forum Samsung Galaxy Note 4
    Last Post: 05-03-2015, 10:40 PM
  2. Replies: 1
    Last Post: 05-02-2015, 01:23 PM
  3. Why are my Google Calendars not syncing to my Samsung Note 3?
    Last Post: 05-02-2015, 12:35 PM
  4. Replies: 1
    Last Post: 05-02-2015, 12:30 PM
  5. Please tell me in which format movie will display in moto g2?
    Last Post: 05-02-2015, 11:38 AM
