1. kazzerly24's Avatar
    I can't seem to find them. Searched for downloads in settings and nothing is there. Am in a pickle. New to Samsung so please be kind!
    05-04-2015 03:43 AM
  2. Shikher Pandey's Avatar
    You should use a file explorer and search in downloads folder. ES File Explorer is a good one.
    05-04-2015 04:08 AM
  3. Desdinova eternal light's Avatar
    Yup a file explorer allows you to acess everything on your external memory
    You should be able to find one in google play or samsung app store
    05-04-2015 05:56 AM
  4. anon8380037's Avatar
    There is a Downloads app. The icon should be in the Samsung folder / tray.
    Samsung has a built in file explorer app called My Files.
    05-04-2015 08:16 AM
  1. Replies: 1
    Last Post: 05-04-2015, 08:55 AM
  2. Is it safe to delete APK files from a Samsung Galaxy tablet?
    By AC Question in forum Samsung Galaxy Tab
    Last Post: 05-04-2015, 04:46 AM
  3. Why my Micromax Unite 2 mobile not charging while in on mode?
    By Krishnendu Ghatak in forum Ask a Question
    Last Post: 05-04-2015, 04:19 AM
  4. Why is my Tecno s9s not charging what might be the problem?
    Last Post: 05-04-2015, 03:33 AM
  5. How can I get my note 3 to boot after root update?
    Last Post: 05-04-2015, 02:30 AM
