I was trying to take a picture. But when i press the camera. Button it said that the camera. Has stop working. I have rest my phone but nothing happens.
Printable View
Welcome to Android Central.
When you say that you have reset the phone, what do you mean?
But at any rate, try Settings, Apps, All, scroll to Camera, and select Clear Cache.
If no good, try Safe Mode, which will test whether the problem is being caused by a third-party app.
