1. AC Question's Avatar
    My wife is totally disabled from the neck down. She can speak and OK Google will dial the call for her. My problem is that the phone closes down after about 10 minutes. I will keep it plugged in but need to know how to keep it turned on at all times. Thank you.
    05-06-2015 02:26 AM
  2. msm0511's Avatar
    What phone are you using?
    05-06-2015 03:07 AM
  3. Larry Haber's Avatar
    I am using a G4 mini, but as my wife has no phone at this time I will buy her whatever works.
    05-06-2015 03:24 AM
  4. msm0511's Avatar
    You should look into a Moto X for her probably. It has an "always listening" Google Now feature that the screen doesn't have to be on. She can just say "OK Google" and the phone will process her request. I think that's the phrase. It's customizable either way in the settings.
    The most recent iPhones allow this too for Siri, but the phone has to be plugged in for it to work. With the Moto X it doesn't even have to be plugged in.
    05-06-2015 03:33 AM
  5. Larry Haber's Avatar
    Thank you very much, I will look into it. DO you know if it is unique to the Moto X or is it the operating system (lollypop)?
    05-06-2015 06:49 AM
  6. msm0511's Avatar
    I think it's available to phones using the Snapdragon 805 processor and above. As far as I know though, the Nexus 6 and some other Motorola phones are the only phones to activate it so far.
    05-06-2015 10:59 AM
  1. Question AT&T G Pro owners
    By PAC757 in forum LG Optimus G Pro
    Last Post: 09-05-2015, 12:18 AM
  2. How do I find the country of origin for an Android browser?
    Last Post: 05-06-2015, 03:15 AM
  3. Getting an M(, just a few Android Questions
    By BriniaSona in forum Android Apps
    Last Post: 05-06-2015, 01:47 AM
  4. Replies: 0
    Last Post: 05-06-2015, 01:31 AM
  5. Samsung S4 wont turn on after an Update
    Last Post: 05-05-2015, 10:26 PM
