1. delhiwarrior's Avatar
    I recently put my SIM into an iPhone 4 as my Android phone (OnePlus One) was giving me problems. I promptly switched back to my OnePlus One, but now it seems that every time someone with an iPhone tries to send me a message, it sends using iMessage. I would assume it's because I put my SIM inside an Apple product. I think there are ways around this by asking the person who's sending me the message to switch their setting to sending just normal messages to me, but I feel like it's quite inconvenient to, first, ask if they have an iPhone and if they do, teach them how to send using regular text message.
    Is there any way I can fix this or am I stuck with this problem?
    05-06-2015 09:21 PM
  2. brick58's Avatar
    before you take sim card out of iPhone, turn off iMessage in messages..then you can use in android phone. I had the same problem
    05-06-2015 11:02 PM
  1. Replies: 2
    Last Post: 08-21-2015, 04:59 AM
  2. Where are the downloads kept?
    Last Post: 05-06-2015, 11:48 PM
  3. Replies: 1
    Last Post: 05-06-2015, 11:41 PM
  4. How do I get a manual for the HTC Desire 610 Mobile Phjone
    Last Post: 05-06-2015, 11:13 PM
  5. Replies: 0
    Last Post: 05-06-2015, 08:50 PM
