A AC Question May 7, 2015 #1 My phone is showing me my full phone data and empty sd data but i dont see where i transfer the data
icu Well-known member Oct 29, 2010 555 21 0 Visit site May 7, 2015 #2 Re: how do i transfer phone data. to a sd card on a lg Hello - so I'm assuming you want to move off some files from your phone storage over to your SD Card? If so, the way I would do it is: - I'd first determine where the most/biggest files were located using something like DiskUsage - https://forums.androidcentral.com/e...google.android.diskusage&hl=en&token=vC2Hw3sq - I'm assuming it's photos and videos, but maybe some games/apps are taking up a lot of space. It's good to see it visualized like this. - I'd then get a file manager such as ES File Explorer - https://forums.androidcentral.com/e...com.estrongs.android.pop&hl=en&token=CJy1zEaC - Fine the files and/or folders you want to move - select them in the file explorer and choose "Move to" and select a folder on your SD card
