1. AC Question's Avatar
    I own an lg tribute with a 16 GB SD card installed and I have a few issues.
    1. I have over 200 MBS of internal storage left and it refuses to let me download even the smallest apps I reset it twice but still no fix.
    2. Whenever a app download fails it seems to leave the apk as I have less space after a download.
    I would like to know how to find these apks and fix my storage issues.
    Thank you
    05-09-2015 02:15 PM
  2. Rukbat's Avatar
    1) Delete everything in the Downloads folder. Once the app is installed you don't need the apk file in there. (I'd copy it to a computer first, so if I had to install it again for some reason, I wouldn't have to download it again.)
    2) The phone needs that 200MB (that's a small amount) for its own storage use. It won't let you use enough storage to leave it with not enough space to operate.
    05-09-2015 09:11 PM
  1. Where are my factory ringtones stored at?
    Last Post: 11-20-2015, 07:28 AM
  2. Why is my screen stuck black?
    Last Post: 05-10-2015, 12:32 AM
  3. Replies: 1
    Last Post: 05-09-2015, 09:54 PM
  4. How can I make an unlocked phone (previously Verizon) work with Cricket Wireless?
    By Garrison Stephens in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 05-09-2015, 09:18 PM
  5. How can I make an unlocked phone (previously Verizon) work with Cricket Wireless?
    Last Post: 05-09-2015, 01:47 PM
