1. AC Question's Avatar
    When I put in the password the connect button is blacked out
    05-09-2015 07:35 PM
  2. srkmagnus's Avatar
    Reset the WiFi router then try connecting. If it doesn't allow you to connect try disabling then enabling WiFi and see if that helps.
    Could you also tell us what phone or tablet you are using?
    05-09-2015 08:17 PM
  1. Replies: 13
    Last Post: 11-29-2016, 02:16 AM
  2. Why can't I access the keyboard?
    Last Post: 05-19-2016, 06:52 AM
  3. Replies: 1
    Last Post: 05-10-2015, 01:10 AM
  4. Replies: 2
    Last Post: 05-09-2015, 09:43 PM
  5. Open message app to new text, not previous mesage
    By jjohnson4499 in forum Samsung Galaxy S6
    Last Post: 05-09-2015, 08:08 PM
