1. jacklyn_c's Avatar
    i have a LG nexus 5 and when i hit the lock button to unlock my phone sometimes the power off option comes up and i cancel it but yet five-ten seconds later my phone will just turn off and sometimes it does this multiple times through out the day. Can this be fixed at home or should i just take it in to the store to be fixed
    05-11-2015 04:12 PM
  2. SpookDroid's Avatar
    I'm guessing your power button is getting stuck somehow. Try cleaning it with compressed air (turn the phone off first, and don't burst the air there for too long or moisture will occur, and that's not a good thing to have inside your phone). Also see if it doesn't seem broken or mechanically stuck.
    If that doesn't help, I'm pretty sure that's what you'd have to replace (either the button itself or the pad on the circuit board it's attached to...or both).
    05-11-2015 04:37 PM
  1. How can I sync my PC Chrome bookmarks with my LG Chrome?
    Last Post: 05-12-2015, 04:24 PM
  2. wake up does not seem to work
    By sjsmith1708 in forum Samsung Galaxy S6 edge
    Last Post: 05-12-2015, 02:40 PM
  3. How do I unlock my Sony Xperia M Dual mobile?
    By AC Question in forum Sony Xperia M2
    Last Post: 05-11-2015, 06:17 PM
  4. Why isn't turning on audible notifications while in a call working?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-11-2015, 04:21 PM
  5. sometimes the phone is warm
    By robinhelenehebert in forum Google Nexus 6
    Last Post: 05-11-2015, 03:48 PM
