1. KelseyRo4's Avatar
    So I had two s6 edge phones and both stopped rotating the screen, so I returned them to Verizon. Today I got an s6 instead, hoping that it was just a problem with the edge. When I got home and charged it, it started getting HOT like the last two (edge) phones. So I panicked and unplugged it. Then I remembered I had an old micro USB charger laying around the house and decided to try it. Lo and behold, the phone cooled back down. It's definitely the fast chargers -___-
    05-11-2015 04:26 PM
  2. SpookDroid's Avatar
    Fast charging DOES heat up your phone. That's a given since you're juicing it up, well, fast. But it shouldn't reach a critical level, but the phones do heat up more than with regular charging (if they didn't change the settings, you should be able to turn Quick Charging off and still use the original charger; you'll see the difference).
    As for the rotating issue... I'm guessing that has nothing to do with the charger, right?
    05-11-2015 04:40 PM
  3. KelseyRo4's Avatar
    The first two phones both stopped rotating the screen after I charged them with the fast chargers
    05-11-2015 04:42 PM
  4. SpookDroid's Avatar
    That's weird... did the heat fry the rotation sensor? So odd...
    05-11-2015 04:47 PM
  5. KelseyRo4's Avatar
    that's what im thinking. both times the accelerometers got stuck
    05-11-2015 04:49 PM
  1. How do I set up email filters in the new Lollipop ?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 06-26-2015, 06:27 PM
  2. What is the cure for wet speakers on the Neo?
    By AC Question in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-14-2015, 02:02 AM
  3. Why does my phone keep turning off when I hit the lock button?
    By jacklyn_c in forum General Help and How To
    Last Post: 05-11-2015, 04:37 PM
  4. sometimes the phone is warm
    By robinhelenehebert in forum Google Nexus 6
    Last Post: 05-11-2015, 03:48 PM
  5. Replies: 0
    Last Post: 05-11-2015, 03:22 PM
