1. AC Question's Avatar
    I hate how the emojis automatically change the set of whatever to a little android. Even from other people I get the little android.
    05-11-2015 08:55 PM
  2. srkmagnus's Avatar
    Emojis are built into the phone, and can't be changed system wide. However, if you are using a third-party service, such as WhatsApp or Hangouts, then the emoji will reflect that of the service.
    What phone do you have?
    ASKER101 likes this.
    05-12-2015 10:57 AM
  3. ASKER101's Avatar
    Lg optimis
    05-12-2015 07:23 PM
  4. gone down south's Avatar
    There are no standard emojis, every system has their of.
    srkmagnus likes this.
    05-12-2015 11:22 PM
  5. srkmagnus's Avatar
    Lg optimis
    Welcome to the forums!
    As mentioned above, every system has their own set of emojis. The only time you'll find a standard is if you are using a service, such as WhatsApp, and that service has their own set of emojis built into the application unless the phone's standard is used.
    05-13-2015 10:54 AM
  1. Were do I find the clipboard on the Moto X 2nd generation?
    By rhonda herndon in forum Moto X (2014)
    Last Post: 06-23-2016, 06:36 PM
  2. How do I get rid of the location at the top right of the screen?
    Last Post: 05-12-2015, 02:53 AM
  3. how do you get to safe mode
    Last Post: 05-12-2015, 02:50 AM
  4. how do i reset my voicemail password
    Last Post: 05-12-2015, 02:47 AM
  5. Show me how you disconnect from a VPN
    By jckatz in forum Android 5.0 Lollipop
    Last Post: 05-11-2015, 07:46 PM
