1. FAHMI BASSEM's Avatar
    I'm planning to get my aunt E7, I'm a Lumia fan, so I know little about android's performance.
    is 410 enough for heavy using?
    will it get android 5?
    any common issues?
    thank you in advanced!
    05-15-2015 12:21 PM
  2. PkPaulo's Avatar
    Its a Mid End phone , the 410 is fine por daily ise , games should work fine most of then , but its a little expensive considering the specs , Maybe you should get a Galaxy s4 which is aroumd the same price but better screen , battery , procesor , and already got lolipop 5.0.1
  3. PkPaulo's Avatar
    05-15-2015 12:51 PM
  1. How can I access my Samsung Gear Fit if I have forgotten the Pin?
    By hondahank in forum Samsung Gear Fit 1 & 2
    Last Post: 06-01-2015, 03:38 PM
  2. Replies: 5
    Last Post: 05-18-2015, 01:36 PM
  3. How do I save images from the internet onto my Samsung Galaxy Tab S?
    By AC Question in forum Samsung Galaxy Tab S 8.4
    Last Post: 05-16-2015, 12:56 AM
  4. Replies: 0
    Last Post: 05-15-2015, 06:10 AM
  5. Why is my Samsung Galaxy Ace 3 screen moving down up?
    By AC Question in forum Samsung Galaxy Ace
    Last Post: 05-15-2015, 05:56 AM
