1. AC Question's Avatar
    I mistakenly deleted some of the brightness on my zeepad 7 and now I cannot see the
    homepage or go to the app where I can set it back to bright how can I reset the brightness?
    05-15-2015 06:25 PM
  2. srkmagnus's Avatar
    Try getting into a dark room and see if there's any visibility of the screen. If not, then you might need to factory reset to restore if you can access the recovery.
    05-15-2015 06:56 PM
  1. Restoring older HTC Backup file
    By mkdll in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 05-16-2015, 03:57 AM
  2. Replies: 1
    Last Post: 05-15-2015, 08:05 PM
  3. How to update LG Motion to Lollipop 5.X?
    By AC Question in forum Legacy Android & Other OS's
    Last Post: 05-15-2015, 07:11 PM
  4. Replies: 0
    Last Post: 05-15-2015, 05:27 PM
  5. Replies: 0
    Last Post: 05-15-2015, 05:25 PM
