A
AC Question
XT 1068 dual sim question
I put a similar question in the 2013 forum, prolly wrong location.
Can anyone confirm what happens to sim slot 2 if I turn the radio off on sim slot 1?
I understand the '1068 is 3G on sim 1 and 2G on sim 2, but can sim slot 2 work with 3G - or at least switch to 3G if sim slot 1 is turned off ? This would be like saying I wish the '1068 wasn't dual-sim active, but I don't need both sims hot all the time, I only need occasional use for retrieving data/browsing on sim 2 (And I don't have great 2G coverage for voice/text in my area, so I almost always have to use sim 1 for 3G voice/text) ).
