1. Carul's Avatar
    I was on kik and we decided to make videos of each other's house's (we are internet friends). I took a bunch and now it was her turn. before that I was looking at some of the other videos i had in my gallery. I was getting tired of pressing the "just once" button so I decided to click "set as default". Now if I try to load her videos they won't show. Can someone please tell me how to turn the default off?
    05-21-2015 10:23 AM
  2. kyleiniowa's Avatar
    Go in to settings, find the "More" tab, and open the "Application Manager." Find the app you set as default for videos, click on it. When in the settings for that app, scroll down and under the "Launch by Default" section, tap "Clear Defaults." Hope that helps!
    05-21-2015 10:28 AM
  1. Replies: 5
    Last Post: 05-26-2015, 03:51 PM
  2. Replies: 7
    Last Post: 05-22-2015, 10:06 AM
  3. Why can't I connect to the Google Play store?
    By AC Question in forum Google Play Store
    Last Post: 05-21-2015, 10:36 AM
  4. Replies: 1
    Last Post: 05-21-2015, 10:34 AM
  5. How do I connect my LG G2 to my pc?
    By AC Question in forum LG G2
    Last Post: 05-21-2015, 09:54 AM
