1. t84a's Avatar
    I have a Galaxy S6, Galaxy Tab S, and MS Outlook running on my PC. I guess ideally I would use Google Calendar on my portables and then sync my PC Outlook with Google Calendar. Sounds easy but I have no idea how to do it. I think I was using Skies to sync my Tab S with my PC but Skies does not support the S6. There has to be an easier way even if I have to buy something. I appreciate all responses.
    05-21-2015 11:24 AM
  2. Almeuit's Avatar
    For your Android devices you should be able to put your Google Account on them and set "Google Calendar" to sync. Also ensure to have the Google Calendar app on your phone.
    Then for the PC you can just go to https://www.google.com/calendar to manage it via your PC .
    05-21-2015 11:32 AM
  3. t84a's Avatar
    Thanks but I use MS Outlook on my PC.
    05-21-2015 11:48 AM
  4. anon8380037's Avatar
    Kies is being replaced with the new Smart Switch program (with an app for first time device transfers).
    I now have both running on my W7 pc, and have a regular backup to both for my Note 3 (silly but hey).
    Now my Smart Switch programme has a tab for syncing to Outlook. I have seen other pc screenshots where it's not present, so Idk.
    I can sync with both programmes to Outlook 2007! (actually 2003 upgraded).
    Also Smart Switch has some less sync functionality I think than Kies, or doesn't do media transfers, I forget. Someone showed a way to get more from Smart Switch settings on a pc.
    The file areas they do a full backup of may vary too.
    Also consider the Outlook. com app and MS suite of apps. I don't know if it's entirely synced to the pc outlook program or Exchange, but the app displays the calendar and Outlook / live email.
    I can also view my Outlook calendar on the S-Planner and Google Calendar apps.
    - Madd54, always coming to you with half an answer -
    05-21-2015 12:57 PM
  1. Replies: 6
    Last Post: 05-26-2015, 12:02 AM
  2. Replies: 2
    Last Post: 05-22-2015, 02:36 AM
  3. Why does my phone battery get heated on the charging period?
    Last Post: 05-21-2015, 04:00 PM
  4. Replies: 1
    Last Post: 05-21-2015, 12:11 PM
  5. How can I get facetime on the Optimus L70?
    By AC Question in forum LG L70
    Last Post: 05-21-2015, 11:14 AM
