1. Heaven Starr's Avatar
    I have a blue bold 5.0 that has issues I have trued to get 4g and no luck I did the APN settings went to phone and punched in a code *#*#4636 something of the sort got into my phone info and I can't switch the gsm to LTE and all I can switch it to is unknown...what gives
    05-22-2015 01:21 PM
  2. Crashdamage's Avatar
    Have you tried contacting your service provider for help and correct APN settings?
    Android since v1.0. Linux user since 2001.
    B. Diddy likes this.
    05-23-2015 01:37 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Crashdamage's advice is good. Which carrier do you have? Are you able to view the APN settings and make sure they're completely the same as the ones the carrier lists?
    Also, what's the exact name of the phone? I can't find a Blu phone called the Bold anywhere. Are you certain it has 4G capability? Not all phones do.
    05-23-2015 01:42 AM
  1. How do I edit the contacts for my S6 on my pc?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-23-2015, 08:11 PM
  2. Replies: 1
    Last Post: 05-22-2015, 01:22 PM
  3. Replies: 0
    Last Post: 05-22-2015, 01:20 PM
  4. Replies: 0
    Last Post: 05-22-2015, 01:17 PM
  5. Why has my contact list stopped working?
