1. AC Question's Avatar
    i dropped my phone in water and i put it on and everything is working perfectly fine, the only problem i got is that my sound isnt working, when someone phone me you can hear the ring tone perfectly fine and then when i answer i cant hear the person and that person cant hear me, i was also taking pictures on my phone after it fell in water and half the pictures are not there, please tell me what i can do so it can work normally again?
    05-23-2015 05:57 AM
  2. LucaL's Avatar
    You might try putting the phone in a bowl of rice for some hours because rice absorbs water. If you're lucky the phone will be less damaged.
    05-23-2015 07:03 AM
  1. Replies: 8
    Last Post: 02-14-2018, 02:35 PM
  2. Why is my Note 3 showing 'In a call' when connect to bluetooth in CRV?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 05-23-2015, 07:49 PM
  3. Replies: 1
    Last Post: 05-23-2015, 05:55 PM
  4. What is the yawning Like Noise my phone did?
    By razza1987 in forum Samsung Galaxy S6
    Last Post: 05-23-2015, 08:12 AM
  5. Replies: 2
    Last Post: 05-23-2015, 07:41 AM
