1. sross91's Avatar
    I have a new tablet from HP. I had it for two weeks now. The first couple weeks when I charge it, it would stay at 100% for a few hours before going to 99%.
    The past couple days it would go down faster to like an hour or thirty minutes today before hitting 99%. I would charge it overnight whenever I was done with it. I didn't think this was a bad thing since I read that it wouldn't mess it up or overcharge since it said it stopped charging after it was full.
    This evenimg I noticed my battery percent draining quicker than usual. A few hours ago I notices it went from 86% to 80% when I was out. I tried turning it off for 10 minutes and notice it would go down one percent when not using it. I been using the same charger and have been charging it for the same amount of time every night so I don't know what I have done wrong or what I can to fix it.
    05-23-2015 09:24 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which HP tablet?
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    05-24-2015 06:12 PM
  1. The Google search bar on my Galaxy S6, how do I get it back?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 10-20-2016, 10:35 AM
  2. Replies: 1
    Last Post: 05-24-2015, 06:13 PM
  3. Replies: 1
    Last Post: 05-24-2015, 10:04 AM
  4. Replies: 1
    Last Post: 05-24-2015, 09:59 AM
  5. Where is the privacy tab?
    Last Post: 05-23-2015, 09:40 PM
