1. AC Question's Avatar
    I live in an area with no signal at all, I would like to be able to send messages to other but do they need to have Verizon installed to receive message from me, I installed the viber app but seems you can only call if the other person has do installed the same app, I am maily house bound and cant receive messages or send, so so frustrating.
    05-24-2015 10:08 AM
  2. belodion's Avatar
    Welcome to Android Central.
    Do you not have wifi calling and texting from Verizon?
    Edit: I've just seen this, so probably not:
    http://www.androidcentral.com/verizo...until-mid-2015
    05-24-2015 10:12 AM
  3. dpham00's Avatar
    If you are using a messaging app that counts towards your messaging limit on Verizon then it should work regardless of the other person's carrier.
    If it didn't work then contact Verizon for support
    Sent from my Pearly White Verizon Samsung Galaxy S6 Edge
    belodion likes this.
    05-24-2015 10:27 AM
  4. Golfdriver97's Avatar
    They shouldn't need Verizon, just the same app you are using.
    05-24-2015 10:28 AM
  1. Replies: 1
    Last Post: 05-24-2015, 04:13 PM
  2. Replies: 5
    Last Post: 05-24-2015, 12:54 PM
  3. can't connect to data or text and call in most areas
    By jrahn23 in forum Ask a Question
    Last Post: 05-24-2015, 10:19 AM
  4. Replies: 1
    Last Post: 05-24-2015, 09:41 AM
  5. Replies: 0
    Last Post: 05-24-2015, 09:28 AM
