My phone locked accidentally, how can I unlock it without the pin?
A
AC Question
phone locked accidently
playing with pattern on the screen th ephone locked. It is now asking for a pin code.Dont have one.tried various combinations.
How to get pack tp thepattern recognition mode whe the phone os locked?
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,384
249
63
Log into your Google account via a PC and change the device security settings from there.
Hassan272
88
Re: phone locked accidently
You could use the '0000' PIN code as it's the default one.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,529
4,666
113
Which phone? I've never heard of a "0000" default PIN. Usually, if you fail the pattern unlock, it asks you for your Google credentials.
Hassan272
88
I have an S4, so things might be a little different. On most Android phones you will be given the option to unlock the device using a PIN number after too many failed pattern attempts and it's 0000 by default.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,529
4,666
113
That's interesting--I'm more used to seeing devices ask for your Google credentials after enough failed unlock attempts. Either that, or it just warns you that it will wipe the phone after 10 unsuccessful unlock attempts. Having a default PIN of 0000 seems impractical, because it would allow anyone to break into a phone by simply failing enough unlock attempts. And how do you set the backup PIN to something besides 0000?
anon(5719825)
Retired Moderator
Feb 21, 2013
3,797
I doubt that this is true. Anything I could find in a Google search said that this simply does not work.
kthompson9705kt
