1. AC Question's Avatar
    playing with pattern on the screen th ephone locked. It is now asking for a pin code.Dont have one.tried various combinations.
    How to get pack tp thepattern recognition mode whe the phone os locked?
    05-24-2015 11:54 AM
  2. belodion's Avatar
    Log into your Google account via a PC and change the device security settings from there.
    05-24-2015 01:03 PM
  3. Hassan272's Avatar
    You could use the '0000' PIN code as it's the default one.
    05-24-2015 04:27 PM
  4. B. Diddy's Avatar
    Which phone? I've never heard of a "0000" default PIN. Usually, if you fail the pattern unlock, it asks you for your Google credentials.
    05-24-2015 04:38 PM
  5. Hassan272's Avatar
    I have an S4, so things might be a little different. On most Android phones you will be given the option to unlock the device using a PIN number after too many failed pattern attempts and it's 0000 by default.
    05-24-2015 04:47 PM
  6. B. Diddy's Avatar
    That's interesting--I'm more used to seeing devices ask for your Google credentials after enough failed unlock attempts. Either that, or it just warns you that it will wipe the phone after 10 unsuccessful unlock attempts. Having a default PIN of 0000 seems impractical, because it would allow anyone to break into a phone by simply failing enough unlock attempts. And how do you set the backup PIN to something besides 0000?
    05-24-2015 04:56 PM
  7. anon(5719825)'s Avatar
    I doubt that this is true. Anything I could find in a Google search said that this simply does not work.
    B. Diddy likes this.
    05-24-2015 05:07 PM
  1. Replies: 1
    Last Post: 06-11-2015, 01:09 AM
  2. Replies: 1
    Last Post: 05-24-2015, 04:08 PM
  3. Replies: 2
    Last Post: 05-24-2015, 04:01 PM
  4. Broken volume keys prevent factory reset locked nexus
    Last Post: 05-24-2015, 03:55 PM
  5. Lock screen on forever?
    By scooby d1 in forum Samsung Galaxy Note 4
    Last Post: 05-24-2015, 03:49 PM
