bluetooth will not turn on
I have a rooted s4 active. The wifi works fine, but bluetooth will not turn on, I realize that the rooting procedure may, (probably), has stopped my bluetooth from activating, just wondering if someone much more familiar with these issues might be able to provide some advice besides a hard reset. I might just decide to do without bluetooth, than go through having to re add all the information that is lost with a hard reset, and yes I have everything backed up and an sd card, but you lose so much. Thanks for any help.
