1. 1Achas's Avatar
    I have a AT&T Samsung Galaxy S2. The battery was reading 28 % so I plugged it in. Then it wouldn't charge and I couldn't even turn it on.
    So I took the battery out for 5 minutes, put it back in and plugged it in again. "Downloading. Do not turn of target!!"
    What's going on??!!
    05-26-2015 10:29 AM
  2. B. Diddy's Avatar
    Download Mode is usually reached by pressing Power, Volume Down, and Home at the same time--you didn't do that, did you?
    As long as you're not connected to the computer via USB and actively downloading a ROM, you can power down from that screen--pull the battery for 10 seconds, then reinsert it, but this time, don't power on. Leave it plugged into a wall outlet for 4-6 hours before trying to power on again. Does the same thing still occur? Does the battery even charge up? It might be worth trying a new battery.
    05-26-2015 03:58 PM
  1. Smart Lock - Phone locked after 4 hours of inactivity
    By N4Newbie in forum Legacy Android & Other OS's
    Last Post: 01-21-2016, 10:03 PM
  2. How do I get my calendar events back on my Galaxy phone?
    Last Post: 05-26-2015, 04:09 PM
  3. Do you have a phone number where I may contact Customer Service?
    Last Post: 05-26-2015, 10:27 AM
  4. Why is my phone using lots of storage and only have about 60 photos on?
    By geordigirl in forum General Help and How To
    Last Post: 05-26-2015, 08:43 AM
  5. Will WOT Blitz run on this phone?I might order it if it runs.
    Last Post: 05-26-2015, 08:36 AM
