1. AC Question's Avatar
    So, I dropped my phone running in a 5K...my phone STILL WORKS, despite the screen cracked.
    3 weeks later, now it won't charge. Get the Incompatible Charger alert...and I'm using the Original Charger. I've tried 2 other original chargers, tried charging off laptop-won't charge. I'm thinking this might be covered under manufacturer's warranty...but my glass is broke and costs $250 to replace....
    WHAT TO DO??
    Will manufacturer cover it with a broken screen if my phone won't charge?
    Where's the best place to buy refurbished phone?
    05-26-2015 05:14 PM
  2. belodion's Avatar
    Welcome to Android Central.
    The message may be showing because of damage to or dirt in the USB port. Have that checked. The USB lead may be suspect, too.
    05-26-2015 06:46 PM
  3. Rukbat's Avatar
    Or the motherboard could have cracked in the drop and taken 3 weeks to develop an electrical problem. That's not covered under warranty either. (It's physical damage, regardless of what broke when you dropped it.)
    05-27-2015 12:37 AM
  4. Pat Brown1's Avatar
    I'm having the same issue . did you ever figure it out ?
    07-29-2015 12:37 AM
  1. help froze during update
    By poseidon9447 in forum Samsung Galaxy Tab S 8.4
    Last Post: 05-28-2015, 10:54 PM
  2. Replies: 1
    Last Post: 05-27-2015, 02:56 AM
  3. New phone stuck on screen unlock bootloader ?
    Last Post: 05-27-2015, 02:54 AM
  4. Replies: 3
    Last Post: 05-26-2015, 09:06 PM
  5. My Samsung Galaxy S5 Won't Charge, But It Was Just Charging?
    By Brandon Flakes in forum Samsung Galaxy S5
    Last Post: 05-26-2015, 08:01 PM
