1. Jason Wu Hunter's Avatar
    I bought a USB Ethernet Adapter, DUB-1312.
    It doesn't seem to be working without compiling a driver.
    Can anyone tell me of such a USB Ethernet Adapter that works out of the box?
    05-28-2015 08:08 AM
  2. hallux's Avatar
    So, you used an OTG cable to then connect the USB ethernet adapter? Not likely to work. To get it to work, you'd need DLink to provide an Android driver, or find someone that could re-compile an Linux driver to work on Android, IF you could get it to even install.
    Curious, what is the purpose? You have cellular, WiFi and Bluetooth for connectivity.
    05-28-2015 08:34 AM
  3. Jason Wu Hunter's Avatar
    I've seen some USB ethernet adapter work with Android OOTB, so I need to find such a device.
    I do a lot of cabling and I want to test the cables without bringing my laptop everywhere
    06-14-2015 05:31 PM
  1. Note 4 bricked. Help please?
    By jackjoe1234 in forum Ask a Question
    Last Post: 05-30-2015, 03:12 PM
  2. How can I sharing a calendar on a Note 3s?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 05-29-2015, 11:19 AM
  3. Replies: 2
    Last Post: 05-28-2015, 09:14 PM
  4. how do I find call timers for all calls
    Last Post: 05-28-2015, 08:15 AM
  5. where are the call timers for all calls
    Last Post: 05-28-2015, 07:27 AM
