1. AC Question's Avatar
    I deleted my music off internal, I was told to turn on debugging mode and then I could find out how to recover my music
    05-29-2015 01:27 PM
  2. Rukbat's Avatar
    If you still need debugging mode, go to Settings/General/About device, and tap the build number 7 times. (Yes, Google is that silly.) Then back and you'll see Debugging right above About Device. You can go in there and enable USB debugging. But you don't use debugging to recover deleted files, from everything I know, you use a file undeletion app, like DiskDigger undelete (root) (and the phone must be rooted - you can't recover deleted files from an unrooted phone.)
    05-29-2015 05:14 PM
  1. What apps do I really need using my phone?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-29-2015, 07:48 PM
  2. I deleted music from internal memory, how can I recover on Coolpad 5560s?
    Last Post: 05-29-2015, 05:05 PM
  3. Replies: 2
    Last Post: 05-29-2015, 02:51 PM
  4. How to unlock bootloader in Panasonic Eluga A ?
    Last Post: 05-29-2015, 01:14 PM
  5. How do I enable my location on weatherbug?
    By AC Question in forum Android Apps
    Last Post: 05-29-2015, 12:29 PM
