1. puruahottam's Avatar
    i am using shv-E160s mobile. 4.0.4 andrid version build number imm76d.vh29. before one month its not working properly with home wifi. when i conect outside wife it working but when i am home just authanticate but not conect. in my home all familys mobile is working wel with wifi only my mobile doing like that. please give me any solution what is the problem.
    05-31-2015 12:38 AM
  2. dancing-bass's Avatar
    go into your wifi settings and look for a list of available wifi networks (you should recognize your home wifi). Long press on it and a box should pop up, select "forget".
    select your home wifi network again and re-enter your password. This should solve the problem
    05-31-2015 07:20 AM
  3. Rukbat's Avatar
    If the problem started right after you received an update, it could be some change in the update that's causing it, but we'd need details about the update, the router and the router settings. Try Dancing Bass' suggestion first.
    05-31-2015 04:27 PM
  4. puruahottam's Avatar
    thanks to quick response.
    i tried boss solution many time.nothing to change still i am with problem.
    06-02-2015 01:53 AM
  5. puruahottam's Avatar
    i recieve update in mobile.but i cant without wifi.
    in router case may be router is ok bcoz others mobile is working well in my house.
    06-02-2015 01:59 AM
  1. pairing problem with fitbit charge hr to android 5.0.2
    Last Post: 08-25-2015, 03:07 AM
  2. Replies: 3
    Last Post: 06-02-2015, 04:15 PM
  3. How can I get the phone icon off my lock screen?
    Last Post: 05-31-2015, 09:27 AM
  4. how can I bypass the lock for WiFi
    By MrBtou in forum Alcatel One Touch Fierce
    Last Post: 05-31-2015, 12:02 AM
  5. Why can't I root my Asus Zenfone 5?
    Last Post: 05-30-2015, 11:38 PM
