1. pmjski's Avatar
    I'm new to the android world and even newer when it comes to crossing over into root territory. I've done some research and can't quite find if my version is rootable yet. I have a Galaxy Note 3, version 5.0. The model number is SM-900W8 and I am with Rogers mobile. Is there an available method of rooting this version yet? I would really appreciate any info/links/advice. Thanks in advance.
    06-04-2015 12:35 AM
  2. TaRT zKie's Avatar
    I think you can root your SM-N900W8 like other model of Note3, I'm using Note 3 N9005 and already rooted using Odin3 + CF Auto root. and had been flash also using Odin3.
    you can go to this section for more info about your device: Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    06-04-2015 01:45 AM
  1. How can I fix this problem on my phone?
    Last Post: 06-04-2015, 02:06 PM
  2. Replies: 1
    Last Post: 06-03-2015, 11:54 PM
  3. Replies: 1
    Last Post: 06-03-2015, 11:52 PM
  4. Does clearcutlogin mean someone is tracking my Android?
    Last Post: 06-03-2015, 11:50 PM
  5. My Google voice typing no longer works for texting?
    Last Post: 06-03-2015, 11:13 PM
