1. AC Question's Avatar
    when typing on the Android keyboard, where can I add a smile or a frown etc.?
    06-05-2015 01:16 PM
  2. belodion's Avatar
    It depends on what keyboard you're using but usually, pressing one of the keys at or near bottom left or bottom right brings up the emoticons option.
    06-05-2015 04:10 PM
  3. Javier P's Avatar
    Press and hold on the return key. The emoji screen should appear.
    06-05-2015 04:18 PM
  4. Rukbat's Avatar
    Or learn the text for the emoticons - Secret Emoticons for MSN Messeneger : Cool Smileys has quite a few. This one was just a : and a ) (with no space between them). If the recipient's app doesn't translate emoticons (smileys), they'll see the text. (If you use emojis and their app doesn't translate emojis, they see something like [emoji 3].)
    06-05-2015 05:01 PM
  1. Need help, data turns on no matter what I do
    By Jace2319 in forum Samsung Galaxy Note 4
    Last Post: 06-13-2015, 08:28 AM
  2. Replies: 1
    Last Post: 06-05-2015, 05:56 PM
  3. How to retrieve private mode password?
    By AC Question in forum More Samsung Tablets
    Last Post: 06-05-2015, 05:45 PM
  4. How to open messages sent to me still being "downloaded"?
    Last Post: 06-05-2015, 05:04 PM
  5. What am I doing wrong with my battery?
    By reltubm in forum LG G4
    Last Post: 06-05-2015, 04:04 PM
