1. AC Question's Avatar
    I can't find my clipboard in my Kyocera icon cellular phones
    06-07-2015 01:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The clipboard is not an app that the user can access directly. If you want to see what's in your clipboard, go to any blank text field, long-press, and tap Paste. Whatever was in the clipboard will appear, but will remain in the clipboard until you copy something else. Once you select any other text and tap Copy, that will replace what was in the clipboard before.
    06-07-2015 02:16 AM
  1. When is the Motorola Moto G third generation being released?
    Last Post: 06-10-2015, 11:03 AM
  2. Why is my Play Store not working on my Moto G2?
    By AC Question in forum Moto G
    Last Post: 06-10-2015, 08:58 AM
  3. My battery stats.
    By tx_tuff in forum LG G4
    Last Post: 06-07-2015, 09:43 AM
  4. Why does my phone log not work?
    Last Post: 06-07-2015, 01:06 AM
  5. How can I use my number pad for options?
    By wifman in forum Moto G
    Last Post: 06-07-2015, 12:51 AM
