1. onurc's Avatar
    i have android smart tv box , when i started up i can see the android icon then it tured after that to black screen . i did reset buttom also i can see the android box Icon the i see its says system update , but it doesn't update also i see recovering system but its not working i see the line it says installing firmware and nothing is happen it didnt read the firmware for the system , i believe the firmware need to be fix how i can do that please help me , thanks so much in advance .
    06-07-2015 09:40 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Have you tried going to the manufactures website to see if they have any kind of recovery software to fix it?
    06-11-2015 09:26 AM
  1. Is ther Android M Developer on Galaxy s2?
    Last Post: 06-11-2015, 09:25 AM
  2. Replies: 15
    Last Post: 06-09-2015, 12:03 PM
  3. Dropped my LG G2 in the toilet!!
    By masterako in forum LG G2
    Last Post: 06-08-2015, 08:40 AM
  4. Replies: 1
    Last Post: 06-08-2015, 03:30 AM
  5. How do I use talk back mode?
    By AC Question in forum Motorola Droid Turbo
    Last Post: 06-08-2015, 01:36 AM
