A AC Question Jun 8, 2015 #1 downloaded files can't open when i try to open a downloaded file,it shows the 'file can't open'. what should i do?
Almeuit Moderator Team Leader Moderator Apr 17, 2012 32,277 23 0 Visit site Jun 8, 2015 #2 Re: downloaded files can't open It depends on the file type. What file are you downloading?
