1. AC Question's Avatar
    Since the update to 5.0 and now on 5.0.1 when on my work wifi I can no longer access intranet pages when using the name. I can access if I use the IP. When entering the name it is providing a DNS error. I can access it on my tablet that is still using 4.4 and I know there is no issue with IOS accessing the names either. This is a big fault to me and in my opinion a major coding error with 5.0. Any information on this is greatly appreciated
    06-10-2015 10:06 AM
  2. espacepublishing's Avatar
    Looks like you are not connecting to your local intranet DNS server.
    Assuming that you are connecting to the intranet via Wi-Fi. If so, check in your current settings if you are connecting via DHCP (by long pressing on the current Wi-Fi connection in settings). Otherwise if you want to set your ip address manual then make sure that you also correctly set your local DNS server at the same time.
    06-11-2015 01:43 AM
  3. joverr's Avatar
    thank you for the reply, it is not an issue with the wifi connection as I use the same credentials on 4.4 with no issue.
    06-11-2015 09:53 AM
  4. Rukbat's Avatar
    DNS, from the Android viewpoint, works the same whether you're using your own internal server, your provider's server or something like OpenDNS. So if you're only having a problem with your intranet name resolutions, it's a problem in your intranet. (Even if another ROM works, an industry-wide change that appeared in 5.0, but that wasn't matched by the DNS server in your intranet being updated, could cause the problem.)
    06-11-2015 11:53 PM
  1. Replies: 9
    Last Post: 06-20-2015, 09:02 PM
  2. Anyone using Samsung Level On with LG Ultimate II phone?
    Last Post: 06-12-2015, 11:13 AM
  3. Replies: 1
    Last Post: 06-10-2015, 11:34 AM
  4. Replies: 1
    Last Post: 06-10-2015, 11:29 AM
  5. Replies: 1
    Last Post: 06-10-2015, 09:50 AM
