How can I set it up to swipe left to delete text messages?
  • Start date Start date
A
AC Question
Swipe left to delete text message
As you see on the emails you can swipe left and it deletes for you. Is there not something similar for msgs? Do I "have" to tick and select delete?
Re: Can I not left swipe to delete a message in one swoop in the same way I can emails?
Most, if not all, stock messaging applications don't allow you to do this. You can, however, install a third-party application (I'm using Textra) that allows you to do this. If you haven't already tried it, give Textra a try. Plenty other apps exists which are good alternatives to the stock application with this feature, so take a look in the Play Store and see what suits your needs.
Textra: https://forums.androidcentral.com/e...ore/apps/details?id=com.textra&token=YQwqp5nR
SebastianJack
