1. AC Question's Avatar
    every time i add a 236mb mp4 file
    06-11-2015 10:56 AM
  2. Rukbat's Avatar
    The easiest way is to stop using Kies. About the only things it's good for are installing the Samsung driver and (sometimes) updating the ROM.
    Drag your files from the phone to the computer, the same way you'd drag any file from point A to point B. (If you're using a USB hub, a 236MB file could be enough to overheat the hub - they're not really made for sustained data transfers like large files.)
    06-12-2015 12:50 AM
  1. How can I root my Samsung Galaxy Ace?
    By AC Question in forum Samsung Galaxy Ace
    Last Post: 06-12-2015, 12:56 AM
  2. Replies: 2
    Last Post: 06-11-2015, 01:10 PM
  3. Replies: 1
    Last Post: 06-11-2015, 01:09 PM
  4. How do I unlock my phone when I'm locked out?
    Last Post: 06-11-2015, 01:03 PM
  5. how to make a font thicker, bold
    Last Post: 06-11-2015, 01:02 PM
