1. jordanblack209's Avatar
    i tried to factory rest , clear sd card , clear cache but when i turn my phone back on all my data is still there and then it seems like the problem is gone but after 5 min of it being back on everthing starts crashing again and i mean everything.. settings , apps , the 2d home, anything you could think of crashes !!! can someone please help me .
    06-11-2015 08:26 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? I'd try booting into Safe Mode, but we need to know which phone you have first.
    jordanblack209 likes this.
    06-11-2015 08:46 PM
  3. jordanblack209's Avatar
    i have the huawei ascend G510
    06-11-2015 09:41 PM
  4. B. Diddy's Avatar
    06-11-2015 10:22 PM
  5. jordanblack209's Avatar
    thank you that helped alot , but now my apps are not responding , but at least my phone is usable now thank you so much .
    06-11-2015 10:55 PM
  6. B. Diddy's Avatar
    What that means is that some app you installed is causing the instability. You may have to uninstall apps one by one until the problems stop. Or do a factory reset and reinstall apps one by one until the problem recurs.
    06-13-2015 12:33 AM
  7. Badjas's Avatar
    I have the same problem with my Huawei g510, but the link you send doesn't work.
    Do you have a new link?
    Thank you!
    02-01-2016 09:17 AM
  1. Replies: 5
    Last Post: 12-24-2016, 11:16 AM
  2. What are some advantages my note has over iPhone?
    By brick58 in forum Samsung Galaxy Note
    Last Post: 06-13-2015, 12:39 AM
  3. My s4 wont allow me to download apps.
    By Casey Ibarra in forum Android Apps
    Last Post: 06-11-2015, 08:55 PM
  4. Phone suddenly slow on home wifi
    By aleeesa in forum Ask a Question
    Last Post: 06-11-2015, 08:54 PM
  5. how do I sync devices on candy crush
    Last Post: 06-11-2015, 08:08 PM
