'Mobile Data' missing from quick settings panel, where could it be?
AliVardz
14
Woke up this morning and 'Mobile Data' seems to be missing from the quick settings panel and I cant figure out how to get it back
Re: 'Mobile Data' missing from quick settings panel
Seems to be an issue on all devices running 5.0 or greater,
Thought so, glad to see im not hallucinating because it was all good before i went to sleep, woke up in the morning and it was gone
i am facing same problem since last night .. Mobile data disappeared from quick settings .
Same problem here ( galaxy s6 edge) is there a way to get it back, isnt so comfortable to go in settings every time i want data mobile..
Same issue this morning, O2 said only way to get it back was to do a backup, then factory reset the phone which I have just done and the mobile data button is back. Bit of a pain though, don't know what samsung are playing at.
i have the same issue! What is happening with my my Galaxy S6, it look like so many people have this problem today !!
might give this a go when I run out of patience would prefer not to have to go through the trouble though
Software update less then 24 hours ago
Running android version 5.0.2
Problem still not solved
Good news everybody
Download "QuickPanel Restore" from Galaxy apps and follow instructions
Problem solved
Here's mine on VzW:
It's still 5.0.1
That's all for now.
I have downloaded this app and when I run it, it says already updated. My mobile data icon and other icons are still missing. Any other suggestions?
i turn on the airplane mode and disable it, problem solve😲
sandysharma8u
