1. AC Question's Avatar
    Hello Frieds,
    I have an Asus Iconia A510.
    Steps I did before I got to briked:
    I had installed 4.2.2 with the CyanogenMod and I had the CWM recovery version 6.0.4.9 on it. Everything worked (almost) perfectly.
    I wanted to upgrade to Lollipop 5.1 with the CyanogenMod distribution.
    (Because I did not know about the new security in 4.2.2 USB debug, I did not authorize the tablet to connect to my PC bore starting the upgrade !!! BIG MISTAKE )
    I did a backup with recovery
    Before installing the CyanogemMod I've read I had to upgrade the recovery as well.
    (Again, I did not saw the recovery for the A510 had to be with TWRP ... not CWM, second big mistake)
    The problems starts:
    After upgrading to CWM 6.0.5.0 and rebooting I had a big surprise ... error, cannot find update.zip and reboot ... I'm not able to boot 4.2.2 anymore.
    I did a backup before, so I wanted to restore ... no access to recovery options.
    I trid to use ADB with a USB connection to push the old CWM version ... got message Offline.
    Updated the android SDK and got the latets USB driver.
    Not I have Not authorized.
    Since I can't boot the OS, I don't have the RSA popup, so I can't authorize .
    Briked !!!
    Is there a trick to "bypass" the USB protection?
    I've open the tablet and I have access to it's internal component, in the old days there was a way to "reset" a bios or "flush" a flash memory by "jumping" the ships connectors. Is there a "hardware" way of accessing the ships/flash or something to give it a jump start?
    Any idea or help would be appreciated!
    Thank you !
    06-12-2015 10:56 AM
  1. Replies: 20
    Last Post: 07-14-2015, 04:02 PM
  2. Replies: 1
    Last Post: 06-12-2015, 01:35 PM
  3. Replies: 1
    Last Post: 06-12-2015, 12:27 PM
  4. Wifi Extender to use w/ Phone?
    By GeminiTroll in forum General Help and How To
    Last Post: 06-12-2015, 10:51 AM
  5. Replies: 0
    Last Post: 06-12-2015, 10:41 AM
