1. AC Question's Avatar
    Printer was working fine and all at once it just wouldn't print
    06-12-2015 05:32 PM
  2. dpham00's Avatar
    What device are you using to print from, and what printer do you have?
    Sent from my Verizon LG G4
    06-13-2015 06:58 AM
  3. Rukbat's Avatar
    I use Cloud Print and that happens once in a while. I just delete the printer, then add it again. (If your printer is on wifi, and you reset your router, or connect a device while the printer is off, the printer's IP address will change, and nothing on the network, including cloud printing, will work.)
    06-16-2015 07:42 PM
  1. audio problem in my new Wiko bloom
    Last Post: 04-12-2016, 03:30 PM
  2. Why does my S-4 turn the ringtone volume down?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 06-16-2015, 04:50 AM
  3. Lens on my M8 scratched?
    By terryh215 in forum HTC One M8
    Last Post: 06-14-2015, 10:31 AM
  4. Replies: 1
    Last Post: 06-13-2015, 03:06 AM
  5. Replies: 1
    Last Post: 06-12-2015, 07:12 PM
