Re: My tablet hcl me u1 not reset...
Welcome to Android Central! How are you resetting the tablet? Are you going to the Settings>Backup & Reset menu and selecting Factory Data Reset there?
Are you saying that after the factory reset, soon after you see that apps have been reinstalled? This can be normal behavior, if you have the "Automatically Restore" option checked on in Settings>Backup & Reset. Uncheck it before doing the factory reset. Also, after the reset is complete and you've finished the Setup Wizard, go immediately to the Google Play Store (if it's on the tablet), swipe in from the left, tap My Apps, and stop any apps that are automatically installing. If you have a different app store, go there and see if any apps are installing.
