1. AC Question's Avatar
    when i try to reset he reset for while.then app are come again.now what i am using?
    06-13-2015 12:32 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! How are you resetting the tablet? Are you going to the Settings>Backup & Reset menu and selecting Factory Data Reset there?
    Are you saying that after the factory reset, soon after you see that apps have been reinstalled? This can be normal behavior, if you have the "Automatically Restore" option checked on in Settings>Backup & Reset. Uncheck it before doing the factory reset. Also, after the reset is complete and you've finished the Setup Wizard, go immediately to the Google Play Store (if it's on the tablet), swipe in from the left, tap My Apps, and stop any apps that are automatically installing. If you have a different app store, go there and see if any apps are installing.
    06-13-2015 12:51 AM
  1. Why aren't my Google Play games achievements syncing?
    By AC Question in forum Google Play Games
    Last Post: 11-20-2016, 06:54 PM
  2. Got my aluminum bumper case.
    By tx_tuff in forum LG G4
    Last Post: 06-22-2015, 10:36 PM
  3. Why I cannot wake up my LG Magna when it goes to sleep mode?
    Last Post: 06-13-2015, 01:14 AM
  4. Why does my battery percent go down instead of up?
    By AC Question in forum Chargers and Batteries
    Last Post: 06-13-2015, 01:02 AM
  5. Replies: 1
    Last Post: 06-13-2015, 12:54 AM
