1. tprincess1963's Avatar
    Tried to use my bluetooth with my s2 galaxy and the min it pairs with media audio and phone it won't play thru speakers when i unchecked boxes music will play thru phone help please
    06-15-2015 07:56 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it a Bluetooth portable speaker? Does the speaker work with other devices? Are you sure the volume on the phone is turned up all the way? If you connect the phone to Bluetooth speakers and the volume is set to zero, then the speaker volume will also be zero.
    06-15-2015 04:32 PM
  1. Can I get some help with my Bluetooth Headphone Connectivity Issue?
    By coder82 in forum Legacy Android & Other OS's
    Last Post: 06-20-2015, 12:06 PM
  2. WhatsApp problem
    Last Post: 06-17-2015, 11:51 AM
  3. File transfer problem.
    By heavyvino in forum Samsung Galaxy S5
    Last Post: 06-16-2015, 05:49 AM
  4. Droid Turbo Headpohne Jack Problems
    By MF_GOON in forum Ask a Question
    Last Post: 06-15-2015, 05:10 PM
  5. play store problem
    By janzx in forum Google Play Store
    Last Post: 06-15-2015, 03:38 PM
