1. littlered29732's Avatar
    don't know, know how it got turned on. don't know how to turn it off. can't answer my phone txt or get to setting to try to turn it off. I have a Samsung galaxy core
    06-16-2015 03:06 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Not sure what you turned on, but I don't think it is TouchWiz is causing the problem. Are you getting a pop up that says TouchWiz has stopped working?
    06-19-2015 07:27 AM
  1. Can't add contacts to People Edge since 5.1 update
    By mmmix in forum Samsung Galaxy S6 edge
    Last Post: 03-07-2016, 04:39 PM
  2. Replies: 6
    Last Post: 07-11-2015, 08:19 AM
  3. Replies: 1
    Last Post: 06-19-2015, 07:09 AM
  4. Six reasons to get the Samsung Galaxy S6 Active
    By Retinella in forum Samsung Galaxy S6 active
    Last Post: 06-18-2015, 08:38 PM
  5. How do I activate multi-user mode on my Samsung Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 06-17-2015, 06:17 AM
