1. AC Question's Avatar
    I installed System app remover (ROOT) by Jumobile and deleted anything that wasn't system except playstore (I know stupid move hindsight 20/20 yadayadayada) and the my phone froze up and I factory reset (hindsight 20/20) and when it came back on evertime i try to view my apps it says "Unfortunately, Home has stopped." playstore won't launch and i have no keyboard. Btw I'm rooted with kingo
    06-17-2015 05:42 PM
  2. Rukbat's Avatar
    Go to LG Optimus F3Q - XDA Forums and learn how to flash the ROM to it (there are two apps you can use, I prefer the LG Flash Tool), and where you can get the appropriate ROM image file. Then flash the ROM and the phone should be back to the way it was when you got it.
    Since you did a factory reset, there's no data left on it to lose by flashing a new ROM - the reset wiped it all out.
    06-17-2015 07:39 PM
  1. LG G4 Where did the default photo editor options go?
    Last Post: 06-25-2018, 10:42 PM
  2. New Nexus 6 Stuck on 5.0 LNX07M
    By rickms80 in forum Google Nexus 6
    Last Post: 06-30-2015, 12:50 PM
  3. How do I see past locations on my navigation app?
    Last Post: 06-17-2015, 07:11 PM
  4. a few big problems...and im compleatly lost.
    By cgt16 in forum Droid RAZR MAXX
    Last Post: 06-17-2015, 05:46 PM
  5. Have a phone with no notificaton light? Try THESE app fixes.
    By MichaelRS in forum Hardware Hideaway
    Last Post: 06-17-2015, 04:19 PM
