1. AC Question's Avatar
    i have a Vodaphone touch screen but it will not turn on before it stopped operating i also need to upgrade software but do not have a memory card installed.
    06-18-2015 01:05 PM
  2. anon8380037's Avatar
    Hello. Welcome to Android Central.
    Are you in the UK with a Vodafone own brand device.
    Can you remove the battery or is it sealed.
    Is it out of warranty?
    It's unlikely it's due an Android update.
    Added ××You would not need an sd card for an update (to say Lollipop), but this update is very large and your device may not have enough internal storage. I don't know if any Vodafone models are due Lollipop. ××
    Did you get screen messages urging you to update.
    If you can no longer power it on, there may be a bulge in the battery and it needs replacing.
    Try holding the power button for 10 seconds.
    Best thing obviously is to bring it to a large Vodafone store, preferably with on site technicians. You may not want to do that if it's out of warranty, but they want you remain a customer and should identify the problem without charging you.
    If you are out of contract you can of course demand a PAC code to transfer your number to another network, though you would need another device.
    If it is a fairly new device, you should dial Vodafone customer service or take it to a store under warranty.
    https://forums.androidcentral.com/e?...token=TuIzN_SS
    06-18-2015 01:43 PM
  1. Replies: 37
    Last Post: 06-30-2015, 06:17 PM
  2. Why does my phone switch off when turn on the mobile data?
    By AC Question in forum Samsung Galaxy S3 Mini
    Last Post: 06-18-2015, 12:57 PM
  3. Replies: 0
    Last Post: 06-18-2015, 12:44 PM
  4. Why don't LNK files open in One Drive?
    Last Post: 06-18-2015, 12:30 PM
  5. How can I get my Galaxy S4 (i9500) to boot?
    By Mrudul Gadaria in forum Samsung Galaxy S4
    Last Post: 06-18-2015, 12:20 PM
